. The LS 6.0 with 6l80E showed up
Me too, or threeIn for updates!
Congrats on getting it to fit so easily (at least from here it looked easyMotor dropped in like it was meant to be there.
Shaved the Transmission a few spots, it’s snug in the tunnel. I did not modify the tunnel except I flattened the body seam lip at the top of the tunnel. If I had removed the intake, it would have been easier to maneuver the drivetrain.
modified the stock crossmember, ended up dropping the transmission mount area by 1/8” for a bit more clearance.
Motor is pushed all the back on the KDS adapters for best clearance for the long tubes.
Engine looks good in the bay, decided to pull engine out to paint the bay.
