I just recently purchased this car and am not able to keep it. It only has 92k original miles. Here is a list of items done to it:
Motor: Stock bottom end, Stage 3 Iron Heads with beehives, port matched intake, LE1, 226/234 .565/.565, NGK plugs, 30# injectors, racetronix fuel pump kit, new coil, optispark, water pumptaylor wires, timing chain/sprockets (oversized for tighter fit), egr delete, air pump delete, F-body MAF, 52mm throttle body, RAISS intake, silicone hoses, and pcm tuned for everything by madtuner.
Trans: Stock, with fresh filter, fluid, 3200 stall convertor
Rear end: 40k eaton with 3.73s, new moser axles
Suspension: Hotchkis coils, kyb shocks, pmt extendend control arms, moog front suspension, Malibu racing sway bars (similar to herb adams sway bars), new cross drilled brakes, pads, brake bolt mod, Clear image automotive tubular crossmember
Exhaust: Clear image automotive quad 1 headers into 3" collectors which reduce into full 2.5" clear image automotive exhaust x-pipe, spintek sportsman xl with polished stainless steel "big kahuna" tips.
Exterior: Smoothie bumpers, 20" Billet Specialties 3d wheels, shaved moldings, wheel wells, and shaved trunk lock.
Interior: Stock with black carpet, console has black carpet, door panels have black carpet, and has a new cluster with circular overlay and red illumination.
Sound system: 6.5" components, 6x9s and kenwood deck, wired for sounds (not hooked up) double zero gauge to trunk, dynamatted doors, trunk, etc.
I'm asking 8500 or best cash offer.
Email me at [email protected] if you want me to send you pics or if you have any other questions about it. Thanks for looking. Joe
