1996 Chevrolet Caprice 9C1 (Project Car)
White exterior / Blue interior
VIN: 1G1BL52P4TR138463
105,976 miles
Up for sale is my 1996 Caprice 9C1 project car. I was previously working on turning this into a drag car, but never completed it. It has been sitting in a garage for the past 8 years. It would make an excellent LS swap candidate for someone with the time and interest.
The car is currently located in Windsor, Ontario. I purchased it in Michigan in 2008 and brought it back to Canada planning to import and title it. I completed all steps of the importation, except for the Ontario DriveClean emissions test and Ontario title. I have all the paperwork related to the importation process. The car currently still has the Michigan title from when I purchased it.
Back in 2008, I pulled the body off the frame and had the frame sandblasted. I POR-15'd the full frame and underside of the body. I put it all back together, changing and upgrading almost every part along the way (see modifications list below).
The exterior and interior of the car are in overall solid condition. The underside of the body has started to develop some surface rust again as a result of sitting. Nothing serious, but it could use another application of POR-15. The frame still looks good, since it had been sandblasted prior to coating.
The car currently has a stock LT1 engine in it. It won't start at the moment, but could be started with a new battery and some fresh fuel. The stock motor was re-installed for the purpose of passing the Ontario emissions test. I never got the opportunity to follow through with this. The car was previously running with this motor and I had it to the drag strip to prove up the rest of the drivetrain and chassis modifications.
As for a price, I really have no idea what it's worth in its current state. All offers will be considered.
Modifications:
Built TH400 w/ reverse manual valve body, transbrake and ~3500rpm stall converter
Cheetach SCS shifter
External transmission cooler
Denny's custom length steel driveshaft w/ safety loop
Factory 8.5" rear end with Eaton posi and 3.73 gears
TA differential cover
Custom rear anti-roll bar
Custom upper and lower control arms
Instant center brackets
QA1 single adjustable shocks
Global West Del-a-lum front control arm bushings
Stock steel 9C1 rims widened 3" by Weldcraft Wheels.
Mickey Thompson ET Street Radial tires P275/60R15
ARP extended wheel studs
Summit Racing fuel cell
Aeromotive A1000 fuel pump
-10 AN feed / -8 AN return fuel system
Aeromotive fuel regulator
AN fuel rails
Griffin aluminum radiator
RAISS intake
Clear Image Automotive exhaust system (currently w/ hookup pipes to stock LT1 cats)
Dual piston front brake calipers
Drilled/slotted brake rotors
Stainless steel brake lines
Summit Racing line lock
Battery in trunk w/ external cut off switch
Autometer tachometer and temperature/pressure gauges
Blink blink sequential taillights
Clear front corner lights
Aluminum front and rear bumper cover supports
HVAC system delete
ABS delete
Air bag delete
Full image album: https://imgur.com/a/EIgd44l
Good luck with the sale. I’d be interested in the widened N97 rims if you wish to sell them separately.
