I’ve got a new problem with my 96 SS.
When shifting from park/neutral into either reverse or forward gear selection, the car will sputter and sometimes die as I accelerate from a dead stop.
I’ve cleaned the MAF, cleaned the TB, installed new plugs and fuel filter, and the car idles and runs absolutely flawless at all other RPMs and loads.
Is there something in the transmission that could be causing this ?
It almost feels like the converter isn’t allowing the transmission to slip the little it needs to when going from park into gear before the car actually starts to move.
I can put it into gear from neutral/park, and it will still idle just fine, but when I give it gas to move it will stumble and sometimes stall.
It gets better when the car is warmed up but still does it, and only sometimes.
Any and all help or recommendations will be greatly appreciated.
Oh ya, Been offline for quite a while.
I hope all the OG’s are still on these forums.
