Are the front springs on a 1a2 anything special? or same specs as a stock civvie wagon?
thanks
Nick
thanks
Nick
would the spring tags be made of paper??Capo,
spring tags are intact?
Shoot me the VIN and I can tell you what springs are on the car.....mebbe...would the spring tags be made of paper??
*sigh* you southern boys are funny sometimes,..
i'll try to get the tailgate open and mebbe read the spid code,. but the body is on the ground, tailgate is from another car, (no key) so i'll have to try and add some power to the switch to try it,..
Nick
Ok,. i don't believe it,. and if they are then someone has added new springs in the last few years,. (inmho)Believe it or not, the spring tags are still on my 92 RMW.
Well thanks anyway,. i appreciate the help,. the pass rear spring was broken , but i wanted to use the fronts if they were heavy duty etc,..Capo,
The springs per VIN are:
LF - 6TM
RF - 7TM
LR - 8RP
RR - 8RP
Conclusion: 1A2 uses nothing special, since the same springs are potentially used on other wagons and non-SEO sedans
