Does anyone know how much 2" lowered inpala springs will lower my 91 9C1? thanks BC
F
9C1's sit about 1 1/2" to 2" taller than an Impala SS on stock springs, so you'd better count on dropping about 3 1/2". That's a guesstimate. My car in the sig below is a 9C1 with 2"-drop (for an Impala SS) springs in the rear, 2"-drop spindles in the front. You'll love the look after you drop it a little, and mine still clears parking lot bumpers.
Same here, I plan on buying some stock impala springs for my caprice also. I just want that lower/level look.
N
has anyone run 9c1 springs with dropped spindles up front with ss springs in the rear? or would ss springs all around be better? i've read the 9c1 springs have better handling characteristics, but is it a bad idea to mix and match?
