Thinking of running two stages in the race car this year, one for off the line and one for down track. Could I use two Mallory 685 boxes to control timing and activation? If so, how would one wire the systems? Maybe one on a wot switch and the other on a button? Time delay box between the two? I have all the parts, just curious on your opinions. Thanks in advance -Alex
I was thinking 75 in one kit and 100 in the second.so you're saying pull all the timing necessary for both shots with one box? And then run the 2nd kit only through the window switch? That sounds like a winner actually
Knowing the details of your race car -- engine, suspension/traction enhancements, gearing, TC, weight, would help decide which of Guilliame's suggested options, or possibly another variation, might work best for you.
I agree it's unlikely you'll need full control (window sw + timing retard) for both stages that would dictate more than 1 box.
It's not really a race car per say, more my "race car" in the fold. Stock bottom lt with heads and cam,3800 stall,and 4.11s. The reason I ask is I was debating pulling the kit out of the another car,as I rarely use it, and use it in the "race car",having 2 full kits at my disposal. It'll have stock style suspension and slicks,I was simply going to split the shot up to ensure good traction out of the hole.figured if you got it, use it! I figured 2 685's might make the timing more precise, but if you guys say it shouldn't matter, that sounds good to me.
that's all I use and spray 150shot right from the green. granted the wagon as a bit more ballast in the rear to hook with. those wheels up shots are using a small 255 drag radial & 205's up front, stiff Monroe sever service shocks and airlift 1000's in the rear wit umi lca's.
these cars work well and even without trick parts get the job done
With that converter, there's no risk in loading the motor at a low rpm with a small shot, so here's what I'd do for a stockish suspension:
Put the first (75) shot on a WOT switch only. Pull 3 degrees from the timing tables of your NA tune. If you find it's blowing the tires off, pull more timing below 5000 rpm till it holds.
Put the 2nd (100) shot on a time delay adjusted to bring it in immediately after the 1-2 shift, and use the Mallory box to pull the additional 4 degrees of timing, and, depending on the strength of your tranny, to cut the spray for the 2-3 and 3-4 shifts.
Guilliame, those were some mild gears! What converter and tire size were you running with that setup? OP is running a 3800 converter and 4.10's; if the motor has any nuts at all, I have my doubts about holding the full shot out of the hole
I don't have the luxury of not worrying about traction. Mine hits the tires hard enough to 60' in the low 1.4x's on motor only. Even with pulling extra timing at launch, I've never successfully hooked up on the 100 shot even with good track prep.
With my stock motor and hitting the 150 shot right out of the hole, it would 60' mid 1.4x's when it hooked, but it required a good starting line. Was running a SS3600, 4.88 gears and 30" tires then.
OP, it doesn't hurt to try as they suggest. If it blows the tires off, pull timing below 5000 in the table till it hooks up.
When I was running nitrous, I had 4.10's a 3200 rpm stall converter and 28" slicks. It would 60' in the low 1.6x NA and low 1.5x on nitrous. Race weight was 4100 lbs. NA MPH was 108-110, and I would get a 8 MPH bump with a 150 shot.
The 3.23 gears are for the current turbo motor.
1.4x is very impressive especially NA, that's A LOT of power available and the 122 mph trap speed confirms this. I seriously doubt OP has the same power/weight ratio as you do, being a stock bottom end and a street car.
my example was simply to show that with skinny radials, non drag suspension parts and heavy stock wheels. these cars can hook well with 150 shot from green. put another 2" of tire, big and littles and drag shocks/springs for transfer. it would take quite a bit of power to over work one of these cars.
Man, this thread took off!thanks to all of you who have contributed.In all honesty guillaume this is my first year running the car and it is a totally new setup. I had planned to use boxed stock arms with airlifts in the rear and a shimmed bar as Gish has suggested. My thought was that using two kits, I can tailor the learning curve of the car a bit as I get used to how it acts on the strip,and from time to time the street.Speaking of stiff sidewall slicks, could anyone lead me in the direction of a set that will fit 9c1 wheels? Also, could you guys glean any starting line techniques you use in the box to keep the trans happy? Thanks you guys -Alex
Related Threads
Chevy Impala SS Forum
1.9M posts
42.7K members
Since 2000
