Will i be able to fit these on my 95 Fleetwood with 245/40/20 tires with no rub. I know our offset limit is -10 to +10 but I 've been looking for rims for a minute, and really like these...I 've seen 22x10's and even 24's on our cars so in my mind I feel like I'm good. However, I have never truly gotten a good understanding of offset...
Limited type 900 20x8.5 +15 offset
I bought them this morning so I hope the work...Any good tire recommendations?
I'm thinking the general g-max as-03 as they are pretty cheap and fairly well reviewed.
i sell rims tires and car audio stuff the ones you picked out would be like $950 for rim and tire and they will fit no rub with 245 or 255 35-20 tires
Thank you ...although I worry if 35 will be enough meat to handle such a heavy car...did you recommend 35's because 245/40/ 20 will run into rub issues or is that what you usually put on b/d bodies?
thats what we usually put on b bodies with 20's when we do 22's its 30 series and 24's are 25 series
you should ask this question in the wheel and tire section. You should be right on point with your intended setup. the 245/40 isn't any wider than the proven 245/35, just taller and you have plenty of room for that. You could even run a 245/45R20.
+15 offset is perfect. You may need to trim the back of the skirt latch assembly, but thats about it.
