I'm pretty sure I just blew through the sun shell on my 96 RMW. I was accelerating hard from a stop, it climbed through 1st gear, shifted into 2nd, something went "bang", suddenly there was no 2nd gear and it was free-revving. I caught it in time to prevent over-revving, so the engine's fine, but I have no more 2nd, OD or reverse. Only 1st and 3rd still exist.
I would get it rebuilt, but I was planning a powertrain swap within a few months anyways, and that swap did not involve a 4L60E. I was gonna be running a 200-4R behind a Buick turbo V6. I really hate the idea of spending $2500+ on a rebuilt 4L60E when I was just planning to swap it out anyways. But the V6 isn't even close to ready yet and I need this car back up and running ASAP.
So how hard is it to run a 200-4R behind an LT1? I know I'll need to modify the transmission crossmember and change the driveshaft length (I was planning those anyways). And I'll likely need an adapter plate to accommodate the BOP bellhousing unless the transmission has dual bolt patterns. What about the TV cable? Is there a way to hook that up to the LT1? And I assume the PCM will need to be flashed to remove transmission control. Can the PCM still do TCC lockup control?
