1 - 20 of 20 Posts
We will time each run then display, and or announce your time. Remember, smooth is fast. There will be penalties assessed for hitting cones or missing the stop box. There are light poles in the zMAX lot and the course will be designed to minimize any chance of contact. Nonetheless, be sure to walk the course beforehand and be aware of where you might end up if you accidently miss a turn. We will have removable window markers on-site. You will need your ID # on the window so we may score autocross.
(Your ISSCA member number will be
your car competition number in all events)
ISSCA Auto Cross:
ISSCA SOP (As amended for 2012 Nat’s) CHAPTER Eight – Article Xl Sec. 2.
If any ISSCA rule conflicts with track/facility rule, track/facility rule takes precedence.
Track/facility rules may change without notice posted here.
GENERAL
1. Late entries will not be allowed missed time runs.
2. Your ISSCA member number is your car competition number.
3. Any sized front and rear tire is allowed.
4. Fuel must be gasoline. No alcohol fuel allowed.
5. There is no minimum weight restriction.
6. Windows must be installed.
7. Big blocks and other motor swaps are allowed.
8. Any transmission may be used.
9. Any drive train is allowed.
10. Exhaust system must meet the requirements of the local track. (some tracks do not allow open headers and some actually have a maximum sound pressure level rule.)
11. All body panels must be factory original steel, (or equivalent), except hood and bumpers (unless model year was available with aluminum panels from the factory).
12. Hood, bumper covers, and trim can be made of any material and of any aftermarket shape or style.
13. Suspension modifications are unrestricted.
14. Windows will be rolled down during runs. Air Conditioning cannot be turned on in the staging lanes or during a run.
AUTOCROSS
Note, these rules may be modified based on track safety requirements.
1. All competitors, crew, and guests must sign a waiver.
2. No alcoholic beverages or illegal drugs will be tolerated.
3. Snell SA 2005 or later approved helmets are required.
4. Mufflers are required.
5. Speed limit on site (off the track) is 10 MPH or as stated by the facility.
6. Running numbers will be your member number or otherwise assigned
at registration.
7. Your car must be in safe running condition.
8. You must have working OEM seat belts or better.
9. All tires must have visible tread over the full diameter.
10. Street tires must run at OEM recommended pressures or higher.
11. Batteries must have the positive post insulated by either tape or
padding.
12. All loose items must be removed from the car including floor mats.
13. Spare tire must be removed or securely fastened in place.
14. Event will be run rain or shine.
15. Entrants will be required to work the course at some time during the
event unless otherwise stated.
16. There will be a two second penalty for each displaced pylon.
17. All drivers will attend a driver meeting and school if required.
18. All entrants will be tech inspected either by track personnel or by
ISSCA staff.
19. Classification will be verified at time of inspection or registration.
20. Windows will be rolled down during runs. A/C will be turned off.
21. Hot-dogging, showing off or unsafe practice will earn a DNF.
22. Passengers will be allowed with proper helmet and seatbelt/harness if
track rules permit.
Note; Two wheels off track will constitute a DNF. Off the track twice will be the end of your day!
CLASSES – Stock, Prepared, Modified, and Race
Determined by the Point Assessment Schedule below.
Determine your class by adding all of the modifications outlined in the Modifications Points List.
TOTAL POINTS
CLASS
0 – 2 Stock
3 – 7 Prepared
8 – 17 Modified
18 and overRace
DIVISIONS will follow the above class breakdowns, and will be designated as:
  • 1958 to 1964 is Division 1
  • 1965 to 1990 is Division 2
  • 1991 to 1996 is Division 3
  • 2000 to Present, Division 4
MODIFICATION POINTS LIST
TIRES, WHEELS AND SUSPENSION
Specialty compound tires 3
Suspension bushing replacement, excluding sway bars & shock absorbers 1
Sway bar revision: Front = 1; Rear = 1 1,1
Change of spring rate 2
Brake conversion 2
Conversion from drum to disk (front or back, each) 3
Adjustable shocks 3
ENGINE
Engine displacement change (per each 3% increase) 1
Engine swap, except for exact replacement of original 2
Removal of emission control device, per device 1
Any air intake system change forward of the throttle body or above the carb 1
Fuel injection or Carb revision on stock manifold 2
Fuel injection or Carb revision with non-stock manifold 3
Camshaft change 2
Valve size change and/or head modifications 2
Ignition and/or computer module change (reprogrammed) 2
Exhaust manifold change 1
Exhaust system enhancements (cat back upgrade, larger dia, etc.)1
Turbocharger or supercharger addition 4
Intercooler addition 4
OTHER
Final gear ratio change less than 20% from stock 2
Final gear ratio change more than 20% from stock 3
Replacement of seats with racing seats as defined by the manufacturer 1
Battery relocation to trunk 1
TIRES
Stock Class- Only standard production DOT tires (or available replicas) are allowed. “Special construction” or “Special compound” tires are not allowed in the Stock class. Tires can be of any size as fitted on stock size rims. For 1958 to 1964, rims can be up to 2” wider than stock. For 1965 to 1991, rims can be 1” wider than stock.
Prepared Class- Only DOT labeled tires are allowed, including “special construction” or “special compound” tires. These tires shall be 200 wear rating minimum
Modified Class- Any DOT labeled tire and any rim is allowed.
Race class- any tire and rim is allowed.
Any rotor or drum of the same size as stock is free.
Brake cooling ducts are free
Nitrous Oxide bottle must be removed
Roll bars are free
Will there be non-competitive laps after the final competition runs? I will be running the Auto-X in competition with Wes as my driver. His girlfriend Jen is coming to Charlotte with us and wants to know if she can run her Lotus Elise after all the competition runs have been made. Because of the insurance requirements, will she need to join ISSCA and purchase the Comnpetition License just to run a couple laps of the Auto-X? You may remember her from Detroit, they rode up with me.
Bump
Anyone have the answer?
Howard,
Sorry for the delay in the response. The ISSCA Bod held their monthly meeting last night, and the question you have asked was brought up in last nights discussions.
Due to the Contracts Signed with Charlotte Motor Speedway,and the current insurance policy. The only people who are allowed to compete, and or use the Auto Cross, and Road Course layouts after the listed events are those who have paid the Nationals Fee's, and who are current / active members.
These are guidlines set from both the Speedway, and Insurance Carrier.
Robert
ISSCA PRO
Robert, Have the results for the auto-x been posted? Thanks, Tom
Tom,
I know that the info for all the events are being worked on, We had a very large turn out for ALL the events and the BoD is working on the lists
Here is a link to a video of me missing the same, D%@m gates 3 times.
Fortunately, I was able to get it together for the 4 and 5 runs and somehow pulled out a third place in the modified class.
Me thinks some stickier tires would have helped immensely, though I believe I was getting really good at drifting. All-in-all I was pretty pleased at how the car handled!
Tim
Robert,
Where can we expect to see the Times posted? ISSCA website or here?
Robert,
I will know more hopefully soon. Many of the ISSCA Board like my self are back at work playing catch up :(
Tom,
Anything yet? THX
Any word on this yet? I REALLY would like to know my time.
Repeat of above questions. Hello, is this thing on? Hello?
Discussion Starter #15
Sure is, We had several Board Members work within four different Events, and different classes within those events. BK is gathering all the info and stats from all the Officers and making a COMPLETE Spread sheet. Please be patient, and as soon as he is finished with it, it will be posted in a seperate thread.
Thanks,
ISSCA PRO
Robert Wagoner
ISSF Honey Badger
Robert,
Sorry guys this is all on me.
I have the spreadsheets of every run for every event.
My question is...not sure how to post spreadsheets here?
Hey BK... glad you like the video!
When you click REPLY, there is a paper clip next to the smiley face. It will allow you to upload attachments.
You "might" have to save them as a .pdf (or not) which could require scanning or something. I don't see an option for Excel. Check it out.
Tim
ISSF Honey Badger
Issca 2013 autocross results
Ok I took the easy way out...
I took a screen shot of all the tabs in my spreadsheets.
ISSCA 2013 AUTOCROSS STOCK CLASS RUN SHEET:
ISSCA 2013 AUTOCROSS PREPARED CLASS RUN SHEET:
ISSCA 2013 AUTOCROSS MODIFIED CLASS RUN SHEET:
ISSCA 2013 AUTOCROSS RACE CLASS RUN SHEET:
ISSF Honey Badger
ISSCA 2013 Road Race Results
ISSCA 2013 ROAD RACING STOCK CLASS RUN SHEET:
ISSCA 2013 ROAD RACING PREPARED CLASS RUN SHEET:
ISSCA 2013 ROAD RACING MODIFIED CLASS RUN SHEET:
ISSCA 2013 ROAD RACING RACE CLASS RUN SHEET:
Cool! Thanks Bill.
1 - 20 of 20 Posts
