Did a search, nothing quite like my situation.
New Walbro fuel pump in summer 09.
New Delphi FPR yesterday
CAI; 93 tune from PCMPERFORMANCE; 52 MM throttle body - also yesterday.
Tri-Y headers; hi-flow cats last week (had to pull head on one side due to broken bolt). No codes after driving a few days after this upgrade.
PROBLEM - running rich, and won't start after warm.
Details:
36 psi fuel pressure while running. 30 - 32 psi after shutdown. 38 pis after pump prime. 3 psi loss after shutdown 2 min, reading about 22 psi after 45 minutes. 45 psi while running with vacuum line removed.
No codes, but hasn't run for more than 10 minutes at a time.
She's flooding. She'll restart if I floor the accelerator. Once running, at slight throttle, or slight movement of the throttle body makes her want to stall, but she catches up and keeps running. At "lots" of throttle (my hand moving throttle body 30% - 50%) she runs like a dream. Loud and NASTY!
Thinking leaky fuel injector, but reading the lower than ideal pressures makes me nervous. Read that at excess throttle, the thing is sucking in enough air to handle the extra fuel (from the leaking injector).
Any ideas?
PS - tomorrow I'll put back in the old regulator. I theorized it wasn't working, and allowed fuel to flow back into gas tank rather than hold pressure on the injectors, thus, no flooding before. My buddy doesn't like that theory. ALSO, will swap in the old PCM to see if its the tune that has it running rich.
I know, lots of variables, but any ideas would still be appreciated.
Oh yea.....I've run out of gas twice. Think I got some bad Marathon gasoline, that caused my fuel light to stop working. Light used to come on at 5 gallons, now it comes on at 1 or 2 gallons.
PPS - I work for Marathon Oil Company - imagine the irony. cwm3
Details:
Any ideas?
