1 - 9 of 9 Posts
I use to have 255/35/20's all the way around on my last set of 20s. With my new set I would like to get 285/30/20s on all 4 corners. I have eibach springs... will I get any scrubbige? Thanks
Probably up front....at least that was my experiance with 275/ width tires.
KW
Mine only rub the frame and sway bar when it turn it lock to lock. No damage to the tires...
hey man sweet ride. are you able to drive up and down on the highway with them 20's on there? i got a set and i am scared to put my **** on the highway. holla back.
20's in the ATL????
On a side note, I run 285/30r22's dropped and tucking with NO RUBBING even during u-turns.
Originally posted by bustn:
20's in the ATL????
Its your fault Mr. Pricey! :D J/p .... All I know is these 15" 9c1's are hurtin my eyes
Discussion Starter · #9 ·
Got 285/30/20's on 2 cars. One96 Impala SS with cut springs which are basically riding on the stops.... got some Hotchkis springs here just need to put the m in. They are on 20x10's with a 6" back. They rub on full lock but not bad at all.
Got the same tires on a 94 Wagon with lowering springs (not sure what kind) on 20x10's with a 6.25" back spacing and they rub more. The extra .25 makes a big difference but I needed it to clear the outer edge of the wheel well on big dips.
It is a pain in the butt with the rubbing especially since menuvering these things are a chore to start with in tight spaces and U-turns.
Price to pay for big tires but heck I am happy with both setups. Will post picts once I figure how.
1 - 9 of 9 Posts
