I just recently purchased a 96 BBB. When looking under the hood I notice the 2nd cooling fan was rigged up. The previous owner had a wire running from cooling fan fuse to the hot wire on the fan plug on the harness, which makes the fan stay on all the time. When I removed the wire from the harness plug fan went off. Tested continuity between fuse and harness wire and there was no continuity.Thought the fan harness was bad but fan wouldn't come on at all if harness was bad. Thought maybe the fuse box was bad. Does anyone know what the problem could be.
