just had 3;42 gears put in...drove bout 10 highway miles then parked for a week when i jumped in, the abs light and check engine are now on...the code reader says 2nd to 3rd shift soloinoid is bad. but tranny guy claims that the ecu will lock it into 3rd when its in drive if it detects bad unusel motor speed. im able to down shift into 2nd but thats it...so bad solo?? or maybe cause i didnt put in the new reluctor?? any of this ever happen to you guys????
Super Moderator
Yep. It doesn't mean the problems are related though. Did you put the proper ABS reluctor in on the 3.42 gearset when the gears were installed? If not, that is probably causing your ABS light. If the code reader says the solenoid is bad, then check and replace it.
