1 - 20 of 32 Posts
3.73's......what the SS should've come with ;) !
KW
+1 I've driven vehicles with both, and while the 4.10s are fun, highway driving takes some getting used to (spintech exhaust+cruising at ~85mph +4.10s=headache). I think 3.73s are the best compromise.
Def look at an aftermarket Posi too. Eaton or the Detroit Tru-Trac are 2 good ones.
+1 I've driven vehicles with both......
I have both.......in my two stroked B-bodies.........
The 9C1 with 3.73 gears is my daily driver ;) .
KW
I've had the same question about 373 or 410. Do your opinions change if the car has a T56?
Jonathan
Definitely changes with a T56. Most with stock motors recommend 4.56's for stock tire height. With a Stroker or a strong 350 you can get by with 4.10s. General concensus is that 3.73s are too tall off a gear for use with a t56.
+1 to all above posts
Nothing less then 4.10 for t56
and 3.73s for automatic street car.
I get good gas mileage if i keep it under 80 with 3.73s
Im AT around 2600/2700 RPMs with 3.73s at 80mph.
4.10's aren't as bad as you might think on the street- I ran them on my '95 for a couple years after driving a friend's Tahoe that was equipped with them- as long as you aren't cruising all day at 80- Every time you toe the throttle, you will smile-
See if you can drive someone's car with either set, before you decide- you might be surprised-
I'd recommend 4.10's as long as you don't cruise over 80MPH often, above that they get annoying cause the RPMs are up over 3000.
I'm not gonna lie, 456 just sounds like a lot of gear. I talked to a guy here at work who is all in to the F-body stuff and 410s is all they will go. Is it the extra 1000 lbs on the Impala that warrants the extra gear?
Jonathan
96 DGGM
I'd recommend 4.10's as long as you don't cruise over 80MPH often...
+1
While I DON'T regret my 3.73s, I sort of wish I installed 4.10s instead...
But it spins 'em easy enough anyway!!!:D
........456 just sounds like a lot of gear...........Is it the extra 1000 lbs on the Impala that warrants the extra gear.........M
Hell yes!
There is no comparing B-bodies to F-bodies when it comes to gear, TC stall and cam selections.
KW
+1. I LOVED my 3.73's with the auto. Now with the T-56 the 3.73's feel like stock gears again.
Thanks for that. Good to hear from someone who has been right where I will be. Gears on the stock motor (or MILDLY modified with external bolt ons) and trans while I work my way forward. Do you think you'll go to the 4.10 or make the leap to 4.56?
i hear 3.42's do the same as 3.73's but use less gas
and if you rolling 22's or bigger 4.10's is the way to go
but i have 3.73's ;)
but i think ima go with 3.42'son my next bbody *95 DGGM*<--- thats what i want :(
I miss my 4.10's in my 4L60E car.
I miss my 4.56's in my T56 car.
1 - 20 of 32 Posts
