Im gathering parts for a 396 motor. The only nagging concern of then the wife saying its a waste of money is the fuel part of it. I plan on making 450-500 rwhp (hopefully closer to 500) and will the stock lines support it? Will the walbro 255 lph feed enough fuel for that or should i go with my plan and build an entire new fuel system ie cell braided lines badass pump.
Thanks for any help
1996 BBB
1) 500rwhp is going to be pretty hard even with a 396 without going with a BIG solid roller...even then...
450rwhp would probably be a better goal for a streetable setup IMHO.
2) one 255lph pump with stock lines should be sufficient for an all motor stroker.
With my 396ci i used the racetronics pump and harness with stock lines. My 95 impala went 10;84 with a 150 shot.
thanks for the help. The cars really isnt going to see the streets that much. But now I know i dont need to make a new fuel system.
.............But now I know i dont need to make a new fuel system.
But you WILL need a lot of compression......and a big cam (probably solid roller) if you want 500 HP at the wheels.
KW
Where's the 396 questions??? I was expecting 2 pages.....
I guess your question is answered though, so all is good :).
