1 - 11 of 11 Posts
hi.. all :D
I have a Caprice 454ci engine :D
And I want to (upgrade) my engine .. cwm3
and I have two options cwm4
, Stroker 496 with 4340 eagle dual key way crank
, eagle h beam rods L-19 Bolts
, SRP pistons 8:7 Combe
, comp cams solid roller
, Dart Pro 1 Heads ported and polished,
,8-71 blower
, dual 850 double pumpers
it make + 900HP cwm8 cwm8 cwm6
This video
or >? :confused: :confused: :confused:
i buy a BluePrint Engines Pro Series Chevy 632 C.I.D. 815HP Crate Engine cwm3 cwm1 cwm1
http://www.summitracing.com/int/parts/mll-ps6320ctc/overview/
And the difference between the price of them is not to much ....
if you are in my position what you gonna on ? and why
i need to your opinion and Thank you very much ... :D :D
Moderator
with out knowing anything about the motors id say
632 keep a sleeperish look, but then again the big hood and a big ass charger looks sick....hard choice....
I think id still go 632 as you can always bolt on a charger and go bigger later....
what are u going to do with the 454 :)
but the real answer is the builds of the motor, need specs
He will have to go cowl hood even with the 632. Not to mentionall the other sheetmetal work he has already done to fit the 454. Headers for both engines would be nearly the same dimensions (ideal diameter and runner length). I would choose the 632. the power and warranty are a hard combination to beat.
Chris
The 496 is a time bomb. 632 all the way!
632 without a doubt. Like Rocko said "the power and warranty are a hard combination to beat."
If this is even a legit thing. How about a few pics of said Caprice.
Thank you man for the Comment :D:D
yah it very hard choice cwm3
but i choice 632 ... and i like you idea ! 632 with charger :D wow !
drivability also, what tranny, what gears, what's your goals?
my gear is (th400) and is a stock ... you no man if i buy the 632 engine ... a upgrade my transmission ( what the good TORQUE CONVERTER for the 632 for street and valve body )
my Differential ( 7.5 gm ) stock ( i need to upgrade to cwm3 )
and my goals to make 800 HP on my caprice
my caprice is 1986 -_-
and i want my car to ( pro street ) cwm4
and Thank a lot man
Chris
Thank you alot guys for Comments !:D
now i choice 623 ! :D
but guys if i want a Headers ? or custom Headers ... i dont have in my country :( ... can i have a maybe Hooker Headers or Hedman Hedders ?
they can make i custom Hedders for me ?
and that is my car ( Gregg-O )
Plenty of information out there about Blueprint engines, make sure you know what you're getting.
It looks like they're also known as Marshall Engines Inc.
http://www.complaintsboard.com/complaints/marshall-engines-inc-kearney-nebraska-c214772.html
My .02 on engines, you definitely get what you pay for!!!!
Search Google for reviews and see what you find. Here are some I found:
http://www.camaros.net/forums/showthread.php?t=191597
http://67-72chevytrucks.com/vboard/showthread.php?t=446911
http://www.jalopyjournal.com/forum/showthread.php?t=605823&showall=1
http://www.thirdgen.org/techboard/aftermarket-vendor-review/570737-blueprint-engines-aka-marshall.html
:eek: :eek: :eek:
cwm3 cwm3 cwm3
This is the first time I read this cwm3 :confused:
ok bro it that 632 Blueprint is not good ..? :confused:
this mean? i build 496 with Super ? :confused:
If you were in my position what would you choose? and why cwm3 :confused: :confused:
1 - 11 of 11 Posts
