1 - 11 of 11 Posts
I finally did in the 4l60 in my '93 wagon. It gave up 3rd and 4th last weekend, it was a little slushy after I took that trailer on a long trip in 95+ heat. I guess a 200k tranny wasn't up to the heat....
Anyway, it will be out next week. I'm thinking I better build it for towing, even though 99% of it's life is stoplight traffic.
Any advice? buy a kit?
I'll also be installing a good cooler after I get it back from the rebuilder.
Super Moderator
Have you ever built a 4l60E before?DO you plan on doing it yourself? What is your skill level?
Answer these and i can help you.
No way, I have build many engines but an automatic tranny is like some kind of black magic, I will drop it off for a rebuild, I just wanted to get it right the first time......
Build it for the max it could possibly see... with that said, the money you'll want to invest may vary if it'll be a grocery getter versus a "Saturday Night Special". :D
Age ole response, I know. Shift kits (Transgo HD2) are great. Helps with firmer shifts, reduced slippage, etc. There's a number of other mods that could help reduce the potential for failure. It truly depends on your desire to be fast from redlight to redlight, or just a Sunday cruiser.
At the very least... HD2, BW HE 3-4 clutches, BW forward sprag, wide 2-4 band... I'm sure there will be more suggestions, but decide your extreme first. That'll help you make the right decision for you. ;)
The best and simplest advice is always: Build it to whatever your budget can stand. You can't have "too much" transmission, only too firm a shift for personal taste and your trans guy can take care of that along the way.
Super Moderator
Well if your not building it yourself i would recommend taking a look at our offerings. We are getting ready to run a summer special, at 15 percent off our transmission offerings. The first order will be twenty percent off.
The issue with these transmissions isnt so much the parts but build techniques. I have over the past 6 years built over 1100 of these high performance 4l60E's. And i think that our recipe for these units works. I believe that in the long run you will also come out saving a little cash as well.
Otherwise i would recommend buying a kit from pro built automatics and having your builder install it. HOwever with that said remember its not so much in the parts as in the assembly.
Thanks Shane,
I still need to go meet the rebuilder, but i hear you on the building be as important as the parts... I've been burned there in the past!
I see you sell 4l60e's, what about 700r4/4l60's?
Super Moderator
Thanks Shane,
We also do 700r4's also known as 4L60's. I just sent one to france last fall actually for a guy with a caprice wagon, i think it was a 90 model. Typically you take about 200 dollars off the price of a transmission for the non electronic model.
OK you're starting to get my attention.... How long would it take to get one to me on the west coast?
Super Moderator
I would probably recomment a level 2 if you do heavy towing, along with a 2000 stall converter. Towing is really rough onthe 700R4 ins tock form, but the modifications we do allow you to use 4th without fear of burning the band. The level 2 has a billet 4th gear apply servo so it has more holding power in overrive along with a band made of a carbon composite material. So itholds up to the heat nicely. A good cooler is always a good idea. For a 700r4 and a converter, i could do one to your door for about 1400.00 shipped and everything WITH a converter.
Your looking at about 2 weeks from the time you place the order to the time its at your door. Our lead time right now is about a week, and shipment to the left coast is about 4-5 day via fed ex ground. Let me know if we can be of any help!
-shane
1 - 11 of 11 Posts
