Would a starter from a 5.7 Caprice fit a 5.0 engine?
The reason i ask is because i might have found a cheap starter but its on a 5.7 Caprice.
Anyone?
If i remember correctly, the 305 and 350 uses the same block right? So technically it should fit? I want to make sure before buying it though...
there was a post about this a month ago or so 305 and 350 share starters most anything on a 350 you can put on a 305 or the other way around just not rotating assembly!
305 starters are different from the 350 starters. So, you can not use the 350 starter on the 305. I have one of each and they are not interchangable.
