·OK I did some scans and had a fuel pressure gauge hooked up this morning.
I ran a .073 nitrous and .055 fuel jet
As soon as the nitrous hit (4000 rpm at full throttle) the O2's went to a SOLID .890 to .930 during a 1st and 2nd gear trial. When I say solid, usually as I drive around they cycle high/low all the time as the closed loop attempt to find the perfect AF ratio...
Fuel pressure sat right around 78PSI and held solid.
I know depending on my O2's is not the best case scenario (I'll tune this more accurately on a dyno with a WBO2 later) it seems as though my setup is "safe" so far.
No knock retard was seen.
Spark Advance went from -40 in first at 3400 rpm to -34 with 4 degrees of retard at 4800 rpm.
Spark Advance stayed at -33/-34 throughout 2nd gear from 4200 rpm to 5500 rpm.
Any feedback for me?
Setup is:
30LB SVO injectors
NOS 5176 with high flow valve - jets listed above 4AN line from bottle to solenoids on passenger fender. 4AN to 3AN from solenoids to NOS 20360 58MM TB
Walbro 340 in tank fuel pump (adding the NOS inline tonight for safety)
I have the "good" NOS fuel pump - http://www.azsupersport.com/pics/pump3.jpg
Mallory 685 - 4000 rpm to 5200 rpm window switch (at track it's 3200 rpm to 5200 rpm as I have ET Streets on the car) - 4 degrees of retard
Mike
(I know I emailed this to you George, just got anxious for response...)
Setup is:
30LB SVO injectors
Mike
