Hey guys i konw nothing about radios, so i see in the pic of the adapter that they had the 6.5 and the tweeter. Question is are they running off the same wire or what? can that be done and if so how?
thanks for any help
GrapeApe
D
W'sup Bro
I think the adapter your talking about is the Crossover. Every component set has'em so that the tweets can play specific frequencies and the 6.5 can play a range of frequencies. Yeah, you could say they play off the same wire because that one wire connects to the crossover. from the crossover it splits in two: one for the tweeter and one for the 6.5 :D
Check these out http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14754
Askign about the 6.5's again. are the all in one good or are the 6.5 sub and the seperate tweeter better?
thanks
D
The "all in one" your talking about are actually "two-way" and the link that I provided for you are for some components. I believe you will get more satifaction from the components then you will with the 2-way 6.5's.
Thanks. I see that soem had said that they should be powered. I dont want to power them. Only want to run off of radio. Have a bagby powering them right now is useless.no i was speakign of some 3 adn 4 way components all in one no seperate tweater.
thanks Again
if u know nothing about this stuff. please have somebody help you put this stuff in. or get in done.... so u wont short something out...
