1 - 17 of 17 Posts
i don't really know my cams well
845 have any lump at all?
is it true the CC502 will sound just like a hotcam?
to be honest, i mainly want the cam for the sound
4 things i'm looking for in a cam...
- direct fit
- very lumpy idle
- sound like godzilla when racing with cutouts
- good with nitrous
i know i'm going to have to do 1.6's? and a TC but i'd like something i could drive without those for now.. thanks guys
- direct fit
- very lumpy idle
- good with nitrous
If you want Lumpy go to an 847cam.
I think the 847 cam is way too much cam for a stock motor. He said lumpy idle Danny, not lumpy idle and runs like crap!
The 845 sounds ok, but a good deal mellower than the LT4 HOT...ask Karl Ellwein what he thinks the best sounding cam is.
Originally posted by BIG KAHUNA ****e:
Did somebody say 502?
Oh...the cam...
When I clicked the thread I though somone had a 845 ENGINE, and thoguh to myself, does one even exsist? Might have to cut the firewall a little on that one
Discussion Starter · #9 ·
How did you know Mike?
LT4 Hot is the sweetest sound in camming.
Karl
Agreed. I have had both, and the HotCam sounded real sweet. But the 845 is no slouch, and it seems to have a touch more top end then my Hot Cam did.
Discussion Starter · #12 ·
Those XE cams don't sound all that great to my ears...Karl, you've told me many times in person
Kahuna, you have a completely different combo around the 845 than you had around the hot cam...apples to oranges for a top end power comparo...both of those cams are in the same league for power, 845 makes its torque a little lower on the tach though.
Discussion Starter · #13 ·
ahhh finally some replies lol, great link 94SSman!
alright, can i pull my stock and put in a GM846 with nothing else?
i really like the sound of the 847, what problems would i encounter swapping to that? i'm somewhat a noob to cams & rockers n all & will be having a shop do the work.
could i just tell him 847, 1.6's and better springs? or...
p.s. i dont really want to mess with heads right away unless i Have to thanks guys
Discussion Starter · #14 ·
....i really like the sound of the 847, what problems would i encounter swapping to that?....
Unless you have a LOT of gear and stall, your car will run like s--t using that cam. It's too much for a stock displacement LT1.
Also, you'll really what to have a PCM recalibration if you go with any of the lopey cams.
As Big Bill already stated:
KW
Discussion Starter · #15 ·
Here is my Caddy:
http://www.badbodies.com/exhaust/briancaddy.mp3
Pretty tame exhaust setup
- GMPP845 Cam, Factory pipes, Thrush turbo mufflers, H-pipe, resonators still intact
Sounds slightly better (meaner) now with tubular manifolds on it, but I don't have a clip of that.
Idle is at 850 RPMs I believe, could sound lopier if it was lowered. In the clip I should have dropped the car into first gear and let it lope.
Here is a video clip that doesn't help much for sound:
http://www.badbodies.com/caddy4.wmv
But proves the 845 cam does help torque on stock gears and TC (2.93 gears).
Discussion Starter · #17 ·
I LOVE the way the XE 230/236 sounds. There is a forum member here (can't remember who it is) who has a sound clip of a 383 with the 230/236 on a 112+2 LSA and IMO, it's the best sounding LT1 I have ever heard.
Of course, it's going to sound different with CustomCaddys 350.
1 - 17 of 17 Posts
