Radiator Support Bushing
Here is the Rad Support Bushing setup I ihad from an old Front Clip I bought back in 2007. On this bolt, the Head and the Nut were both 15mm and the bolt is 4.25" from under the Bolt head to the end.
Here are a few pics of it together as I stored them and the 4 or 5 Thick washers. I believe the washers were just used under the Bushing shell to help raise the Body Nose on the Frame (if needed) when aligning the nose of the car. When recently installing these, I think I only used 1 or 2 washers on each side OR may have used none....cant remember. :wink2:
The face of the Bushing(s) with the holes, goes toward the Metal Washers and the Larger bushing goes UNDER the Rad Support.
