1 - 20 of 49 Posts
FLP 2.5" to 3" Headers $700
Eagle 4340 Forged Steel Crankshaft $400
Crower 6" Maxi Lite forged Connecting Rods $900
Mahle Motorsports Forged Pistons 14.2 : 1 Compression $900
JE Plasma-Moly Piston Ring Set $
Coated Clevite H series Cam, Rod, Main Bearings $
Melling Balanced Oil Pump $75
New Oil Pump Drive
LT4 Custom Heads Ported $1600
Rev Racing Valves 2.02 1.57
Extreme Duty Dual Coil Valve Springs $200
Cam Motion Custom Solid Roller Cam $150
Crane Solid Roller Lifters $200
Crane Cams Billet Timing Set $100
Crane Cams 3/8 Pushrods $100
Jesel Shaft Mount Rocker Arms $800
ARP Cylinder Head Bolts
ATI Serpentine Balancer $280
LT4 Sheet Metal Valve Covers $200
Ford Racing 42lbs Injectors $350
Arizona Speed & Marine 1300CFM Throttle Body Billet $400
Custom Cold Air intake with Dual NOS Ports $200
10 Gallon Fuel Cell $100
Summit Brake Proportioning Valve $25
Aeromotive A1000 Fuel Pump Flows 600 lbs. per hour @13.5 volts and 45 psi with Filter with Lines $350
Aeromotive Fuel Presure Regulator with Bypass $75
Custom Fuel Rails #10 Steel Braided Lines $150
Meziere Electric Water Pump $110
Heavy Duty Oil Cooler -12 Braided Lines with Oil Filter Relocation Kit $100
Johnny Winter Turbo 400 Transmission with Trans Brake $1800
Cheetah SCS Shifter $200
Johnny Winter Heavy Duty Racing Flex Plate $50
Johnny Winter Custom 4500 Stall Torque Converter $600
TCI Extreme Duty Gear Reduction Starter $150
Custom Aluminum Drive Shaft $300
8.5 GM Spool 33 SPL $100
Custom 33 Spine Axels $200
GM 3.73 Gear $50
C-Clamp Eliminator Package $100
Dual 10lbs Bottle with Heaters $300
Billet Specialties Dual Bottle Bracket $100
Custom Dual Stage NX System $400
F.A.S.T. Fuel Management System $1800
MSD Digital 7 Ignition Box $450
MSD Pro Coil $70
Dual Optima Yellow Top Batteries in Trunk $50 ea.
HAL adjustable shocks $150
Rear Airbags $50
Daytona Custom Chassis Uppers and Lowers Rear Centering $400
Billit Specialties 17" Wheels with tires $700
Hole Shot 15" Wheels with tires $900
Many more parts to follow, ALL PARTS ADD SHIPPING please send email for questions. [email protected] www.mfracing.com
How many miles/passes on this stuff?
Do you have part numbers for the lifters and shaft rockers?
OH YEA! XMAS TIME! PM sent and will be eagerly waiting to see what else you have!
looked at your website and if everything is truly going: ill take the spool, eliminators, axles, shift light, ta cover and possibly the fuel cell and some more info on the starter like a pn#. thanks bro. sent pm
You have PM.
KW
Crane 1355216
Jesel KCS11258
Its hard to say how many runs on this cuurent setup but I would estimate about 20
Can't find anything on google or jesel's website with that part number.
The lifters show up for a big block. They are for a solid roller?
Well, how much for the console, sans shifter. Still trying to decide whether to buy one or build my own creation...
I would be interested in the four interior black door inserts that hold the door pulls and door latch/ mirror controls. I'm interested in these sections complete, with attaching hardware. I want to install them in a 95 9C1. What do you want for them, and shipping to 77581? Thank you.
1 - 20 of 49 Posts
