Hey i have a 95 SS, it seams to run sorta ruff, and i would not be suprised if it has not had any of the scedualed maitnance stuff done.
What is done and when do these things need to be worked on?
Change plugs, wires and flush all fluids. That should get you in the right direction. And welcome to the forum.
Mav
Optispark
EGR
EGR Solinoid
PCV Valve
Fuil filter
Also check all the vacumm lines to make sure they are not cracked. Make sure the belt is in good condition. Since you have a 95 you might also consider replacing the Ignition coil with a 96 model.
Tony
If the H2Opump and the OptiSpark are both off, you might as well replace the timing chain while you're at it - especially if you think it's the original one.
Describe your symptoms.
(Perhaps this belongs in the 'Problems/Maintenance section?)
