Heyuys,
I got a little question.
Thanks to a forum member I got hold of a set of sillicone hoses for a 9c1 model year 91-92 (at least I think it is)
Can anyone provide me with a picture where all these hoses go to? I have a 305 block.
I have already replaced the hose from the radiator to the thermostat. It looks nice.
I assume they are all heater related hoses?
So far I have 3 hoses left of which I do not know where they go, since I can't find similar black original hoses in the engine compartment. Or where the 9c1 cars back then already much more different then the cive ones?
Any pic of hint would be higly appreciated.
Thnx!
D
Here are pics I found of a 1990 9c-1 with LO5 350
So going off of these pics, I would say the silicone hoses should be the upper(thermostat to upper radiator) and lower radiator(goes from water pump to lower radiator outlet), raditor over-flow tank(expansion tank with one or two lines),and heater hoses 3/4 & 5/8 inner dia...
I will look for more pics(hopefully 91-93 9c-1/9c-6's)
OK I check 9c1.com and according to the 1991 9c-1
brochure, the radiator(upper/lower/and overflow-expansion tank) and heater hoses were the only silicone hoses
http://www.9c1.com/brochures/1991/91_9c1.pdf
Thnx, these are very helpfull!
Much appreciated!
Eelco
Sure thing! :D
But if anyone could get some 9c1 pics from a 91-93 model, I'd appreciate! Every bit of help is usefull!
