My lid and the one I bought to replace it both have this problem. I haven't found a solution. I do have an idea about it though. My thought is to drill a small hole in the corner were the vertical part intersects the horizontal lower left side. After drilling the hole I thought a small roll pin that would protrude just enough to hold it in the proper position and not be too obtrusive. I might have to cut or grind the roll pin a little to make it work.
Mark: Snowman-33
Yeah I've got that problem, and I was thinking something similar like the roll pin idea.
I also thought of using some epoxy in the slot at the end to stop the bow tie from swinging past the normal stop position would be easier.
