I JUST blew out a fuel line...... the leak is at the trans cross-member cwm1 cwm1
THe line is the one that goes from the filter to the fuel rail. Anyone have one they can overnight it to me??
Part is discontinued and no longer avail from the stealership :(
Let me know...... checking local yards, but B-bodies are few and far between here...... 912-610-0059 is my cell
*edit* are ALL the B-bodies the same, IE: L99, Lo3, LO5?
There is a double-barb repair piece that you can buy. I forget which parts store I got it from. You basically cut the line at the break to get clean ends, insert the repair, and push the pieces back together [lots of force]. I also took a piece of rubber fuel line, split it lengthwise, put it over the repair, and then put a hose clamp on each end. It's been there for at least a year.
