Just picked up a real nice dark blue 1993 caprice civi, I'm going to go with the 9c1 look. Anyone try to install a 93 9c1 cluster in a civi car? or a 93 roadmaster cluster in a civi caprice?
I'm going to delete the ROARING fan, and do a cluster mod first thing.
The easiest fan mod is to use the relays, fans and brackets from a 93 FW.
There are kits available to activate the relays, or you could have one turn on when the temp reaches a certain point and the other when you turn on the AC. I have not explored the electrical aspect of it, but the installation is a bolt in for the fans.
If there are a lot of 93 FWs in the yards near you, grab the hard fuel lines connected to the TBI. They have a schrader valve for checking the fuel pressure. The lines are a bolt in (you do not have to use the return line). I think you could pay for your fan conversion by selling a couple of the lines.
DakotaDigital offers a programmable fan controller that's pretty slick.
