whats going on guys? I have a 93 Caprice L05 and just recently ive been noticing a couple issues with the starting and overall idle of the car. First off about 2 weeks ago I started the car and it acted as if it barely wanted to turn over. It only took one turn of the key to get it to start, but when it did the lights got very dim and you could hear that it was somewhat struggling to start. Well that happened only that one time and didn't occur again for a while until one day I was driving and put it in reverse and the car cut off...this was kind of strange so I immediately put the car in park and she started right up. Now a couple of days ago I was driving and a stopped at a light and the car starting acting as if it were going to cut out, the battery voltage started to drop in and out and the lights were flickering a little but I gave it a little gas and it went away.
Its time for a tune up, so Im thinking that may be whats wrong but Im not sure if that is all. The Alternator is less than 4 months old and I'm running 2 batteries (additional yellow top in the trunk). My question is what else could be causing these issues? could it be that one of the 2 batteries is not holding charge very well? Is there anything else that I should look into change out besides the usual suspects of tune up, cap and rotor button, and dizzy.
Cliff Notes
*Car struggled to turn over (sounds as if the battery was somewhat drained)Slow turnover
*Car cut off when in reverse
*Car was cutting in and out (RPMS never dropped just battery voltage)
*Time for tune up, but looking for other suggestions of service or repair
Thanks again
Cliff Notes
Thanks again
