Status
Not open for further replies.
1 - 20 of 75 Posts
[Moderator note: This is for '94-95 Caprice and Impala SS, and also for '96 Caprice. '96 Impala SS has a unique cluster that has it's own problem and repair.]
I posted this a while ago and then the forum crashed, so I also had it on 9C1. net. Now that site is down. So I'll post it here again.
The empty cavity
Remove these 4 screws
clean these points with alcohol and a Q-tip. You can also pull on these points slightly with a hooked instrument so they'll contact the digital head better.
You can see how these contact points are dimpled. Touch them up lightly with a pointed soldering iron. You will need a very delicate touch here. Pretend your a brain surgeon.
And there it is, working again!
Nice writeup John.
I have a dead cluster downstairs that I took the easy route and replaced it. I may just have to try the soldering on it to see if I can make it work.
Excellent write up indeed. Followed the instructions and illustrations to the "T" ! Unfortunately however, my flickering digital display remains the same ?! Gonna upgrade to the Z28 Cluster soon, but wanted this setup to work for the time being. I did notice something though, your check engine light is illuminated (left side, bottom right ). Mine won't come on ? I switched bulbs with known working bulbs and still can't get that one to illuminate ?? Is this a major problem ?
Thanks for posting this. My digital dash keeps going blank in my 95 Caprice Classic, and I was wondering how to fix it! It seems to do it when the weather warms up, and it was a pain in the ass. Now with your help, I'm going to fix it this weekend. Thanks again.
big problem when you take it for a smog check
trying this over the weekend.
wish me luck....
also my blinker lights are out on the display...would this be a fix for that?
ok...
cleaned and soldered the points, but i noticed when i pulled the unit out there were 2 huge black burn points underneath the epoxy. the only thing i can guess is the unit is totally out.
checked all my fuses but nothing works....
next step is to find another one from a parts car and go from there.
my alternator went out and thats when my digi dash died.
think that was the issue.
It worked great for me! I had mine out, fixed and back in the car in less than 2 hrs, and it works great! No more issues.
great info!!! But, if i use a gauge cluster from another car will the mileage change if i rebuild it? or will the computer turn it to the correct mileage?
how did you take the dash apart with the shifter in the way?
did you put the car in drive and hold the break? becuase i cant take it apart with the car in park???
and what did you do to the car before you started to take the dash apart?
did you take the battery out or anything like that?
Discussion Starter #17
You need to turn the key enough to put the shifter into low, without starting the car. They recommend you disconnect the battery to prevent accidental electrical damage. I did not myself.
okay thanks for the info ...i will do that.
and did you need to put solder on the circut board or just touch with a hot soldering iron?
okay i will make sure i do that
thanks you saved me a lot of money.
and are your sure my tranny or anything else wont get damaged by shifting into low without turning the car on?
1 - 20 of 75 Posts
Status
