I need to replace my coil. I read the 96 coil is better than the 94-95 and there is a mod to do change it. But I can't find it can someone help?
wire the two pinks togethers and color match the 3rd one.
what do you do if you need to put a 94,95 coil in a 96??
Another option is to go with the dual plug GM Blaster coil. Straight plug in and you are off, no rewiring or wire splicing necessary. - Peter
Or you can replace it with an OEM style ACCEL or MSD coil, which are more than adequate, no tricks necessary.:D
difference
Thanks, but I went with a 95 Delco. But is there a difference besides one connector(96)or two(95), and the coil wire?
