My caprice lt1 cranks but will not run I replaced the spark plugs ac delco 2 weeks ago because it did the same thing when it rained. the car was running fine no hesitation. The other day it rained heavy I go to start it it just will not run I pulled the plugs are drenched with gas I also noticed smoke from the throttle body .I replaced the ignition coil eariler today. and it still didn't run I running out of ideas can someone please tell me what else I should check for.
Banned
I agree that the opti is most likely the problem . water is a killer to these. some of you down in texas got some flooding rains lately. you drive this is deep puddles it is N/G..
The other issue is the plugs being fouled, and this excess fuel getting into the crankcase.
remove clean dry out OPTI , clean and/or replace plugs. then with the water pump off see if it runs for a few seconds. then put it back and if it works out change the oil.
if you see any oil leaking behind opti replace the seals felpro front cover seal kit.
Thanks guys for the replies. I will pull the opti hope that is the problem how difficult is it to pull the opti spark I had difficulty getting to the passenger side spark plugs
Not difficult at all with the Goldmaster video series. All the cool kids are watching. :)
