do you guys know if i need a specific year for my tranny swap. I have the option to buy a 93 caprice tranny or a 95 roadmaster tranny? Will either of these work for my car? If not do I need only the 94's what trannies will be a direct replacement?
Look in the deivetrain section on this board. There is a way to make the roadmaster tranny work. I agree the 93 won't. Good luck, Jeff
Contact Sherlock9C1.
He has this down to a science. :D
He helped me with all sorts of questions.
An easy way to get a basic idea is to check where the wire harness plugs in. Make sure they have the same number of plug ins. If not, you can still use it with modifications that Sherlock9C1 can instruct you on.
The 95 with definately work, the only question is if it will need modified or not.
