I stand corrected.Is there any reason why he would not be able to use the 94 harness??'95 engine harness has the ABS wiring in it because the module is under the hood. '94 module is under the dash, so the engine harness does not have it.
There are also differences in the pinout of the engine to body harness connectors C204, C205, C207.
Does anybody know this for sure??I'm pretty sure the transmission connector is different between 94 and 95.
Hmmm, i put a tranny from 94 caprice into a 95 impala about 4 years ago and it plugged right in...Its still in the car till this day. I know BigB knows his stuff so maybe he can give some insight...use the original 94 harness, and use the 94 trans, everything will work just fine. you'll need a 94 LT1 PCM though
it'll work fine.
Im crazyHmmm, i put a tranny from 94 caprice into a 95 impala about 4 years ago and it plugged right in...Its still in the car till this day. I know BigB knows his stuff so maybe he can give some insight...
There you go bob,just use the 94 harness,with 95 lt1 and trans.IIm crazy
I didnt think it would plug in.
Ignore me
I believe the 95 trans does, it's called Torque converter clutch pulse width modulation solenoid, TCC PWM solenoid. It's not in a 94 transmission. The wire that connects the trans to the PCM isn't there on the 94 harness. The pin on the trans connector is "U" , check it out to be sure.I thought the 95 trans had an extra solenoid in it not found in the 94?
