I have a black 94 impala ss I'm selling. Im located in Campbell CA. Has a salvaged title from previous owner. Its been sitting for the past year and a half. The motor has about 230k miles. Trans had about 98k miles. Ive owned the car since 2009. The car needs a little TLC but nothing major! Small oil and coolant leak. Needs new header gasket for the driver side. Other wise the car runs fine. Before I stopped driving it I got a new water pump, opti, spark plugs and the diff was serviced.
Registration is paid. Just needs smog. I can recommend a few places if you need it.
Motor: New water pump, opti, and spark plugs. maybe 120 miles. Tri y headers which may need to be re-coated. Stock heads. Custom full exhaust. Exits at rear wheels
Trans/drivetrain: Has a trans rebuild kit with about 5k miles. Yank 3600 torque converter. Dennys siveshaft.
Suspension: BMR front and rear sway bars. OEM front upper and lower control arms. UMI rear upper and lower control arms. Has springs with drop. Might be 1 inch or 1.5 I don't remember.
Interior: Front seat are ripped but still comfortable. Back seats are fine. Driver side window rolls down slanted. Needs to be guided down. All other windows roll fine. Took out the digital dash. Put in a dash from a 96. All tacts work.
I have most of the old parts like front upper and lower control arms. water pump. opti. Springs.
Call or text Ben 4084012525
Asking 3500
