In the past, the discussion about brown discoloration of 94+ Caprice dash tops culminated in a recommendation to use (a) certain cleaner(s) to remove the discoloration, which was apparently something coming through from underneath the top surface.
Now I have 2 96 RMWs. One has very slight discoloration, perhaps as much brown as grey, right by the outer corners where Caprices typically get this. The other one has it much more all-over, and more grey than brown. (This, incidentally, sprouted rather too quickly after I bought the car, and coincided with a quick loss of color off the center armrest, too. So there's certainly a chance that the good color I saw for a few weeks was a dealer special treatment - but even so, the original discoloration might still be a standard feature of the particular dash material.)
And that's my question: If I wash at this (if I knew what the recommended cleaner was - Fantastik spray?) on a 94+ RMW, am I just going to be removing more paint, or am I going to be removing crud?
Should I be painting instead? If so, is there a paint/dye that matches the slightly greyish RM blue, and doesn't add unhealthy gloss?
thanks.
Simple Green took alot of the brown discoloration out of my dash. Unfortunately for me it did not remove it all and I had to have it repainted. It did however take all the brown out of the arm rests on the doors and center council.
I reckon I'll try that on the less-blemished one, and see how it does while I figure out the painting.
Remove it, clean it the best you can, prep it then use S.E.M spray dye and it'll look better then new.
Does anyone have a part number for the best match for the 94-96 RM blue, and photos how it looks next to the OEM color?
I used Awesome degreaser and it worked very well.
I used the Duplicolor dark charcoal, then wet sanded it. It turned out very good considering it was done in my bathroom cwm4
Do you mean for removing the crud that surfaces to cover the color, or do you mean as paint prep?
Is that Duplicolor Vinyl & Fabric?
You don't really mean dark charcoal as a match for 94+ Buick blue, do you?
its Lexol Vinylex, at least thats what I recommend to keep the brown from returning.
been using it for a few years now and it makes a difference.
local pep boys sells it, otherwise internet.
