Noticed a problem when i heard it backfire from under the hood while i was driving it. Drove it about 2 miles and it started to choke out as i give it some gas it will die out n crank right back up but wont stay crunk after the engine warms but at a cold start it stays crunk until the engine warms and then it slowly dies out n wont stay crunk after its warmed up. Any help? Im guessing its the distributor need a lil advice before i change it Land vehicle Vehicle Car Luxury vehicle Mid-size car
Sent from AutoGuide.com Free App
My guess is crunk is running.. In that event, the backfire USUALLY indicates low fuel pressure and the slow die out. Run a fuel pressure test. Is the check engine light on while it is running?
It wouldn't be a bad idea to go to the pcm diagnostic section here and open my thread and follow the link to the other forum and download the new tool out for 94-95 lt1's. ABS and SIR sections are for F body only, but all the engine and transmission stuff is in good order. Then go get yourself a cable and be able to diagnose the car yourself with help from people here and get it fixed the right way.
Also fill out your user CP, a local member might be willing to lend a hand in person.
Chris
Yes crunk means running lol i will get better on not using slang on here but yes the check engine light is on but theres plenty of fuel in the tank still and it runs fine until the engine warms and then it chokes itself on out especially when i try to hit the throttle it shuts off but keep in mind i can give it all the throttle i want once its at a cold start
