'95 Impala SS Headlights Not Working
1163 Views 3 Replies 4 Participants Last post by  Z09B4U
My headlights are not working in my '95 Impala. I have tried other headlight switches, another headlight control module (behind front passenger kick panel), and installed a new dimmer switch (under column) and they still don't work. Does anybody have any suggestions on what the issue could be? Thanks
Time to get out the volt meter and follow the troubleshooting chart in the Factory Service Manual.
  • Like
Reactions: 2
I believe there may be a relay or large fuse on that circuit, Start there.
You might want to look at a circuit diagram.
There is no fuse or relay in the basic headlight circuit.
The basic headlight circuit will work with the twilight sentinel module unplugged.
The headlight switch gets it's power from a FUSIBLE LINK.(looks like a piece of wire).
