Hey guys sorry if this is a double post. I need to replace my radiator in my 95 Impala ss I’ve seen various options for radiators. My question is does my year Impala come stock with engine oil cooler located internally in the radiator? And what brands would you recommend for an all stock motor Impala, thanks a lot guys!
All Impalas came with external oil coolers that are located in front of the radiator. The only Caprice models that did not have the oil cooler are the L99s, and I believe even some of them had external oil coolers.
the stock SS radiator has both oil and tranny cooler
The "external" cooler on the PS (in front of condenser) is also a additional tranny cooler the SS has. IDK if other B-body models also have a external tranny cooler like SS
9C1 SEO option was a "external" oil cooler (usually fleet cop and cab B-body's) that mounts on DS and those radiators did not also include a radiator oil cooler. The DS side tank of those radiators are curved to allow the external oil cooler lines to get around it to the external oil cooler
Some of us have added this "external" oil cooler which also requires different oil cooler lines and the different oil cooler lines do get around a regular radiator
Sorry, not true .
For 94-96 anyway
Impalas had the left rad tank mounted liquid to liquid engine oil cooler
9C1 Caprice had front mounted engine air to oil oil cooler .
Some Caprice LT1s had no engine oil cooler
Those used both rad tanks for transmission cooling
edit: slow typing, Roger beat me to it
