Aight yall when I start the car it idles fine then when I put the car in drive and pull off I have little power at a low rpm and sometimes it backfires in the intake i changed the plugs, coil pack and the egr valve, when i pulled the plugs i had 4 different plugs in the car so the guy that did the tune up is gonna get it when i see him. Also i just install a pype's x pipe system and i have a slight exhaust leak.. but i there's no check engine light at all so any info would be helpful but I'm thinking its the Optispark or the cranshaft sensor..........
Recheck for proper spark plug wire routing and attachment to the opti. Other than that, small vacuum leaks need to be looked for and varified repaired. a vacuum guage here will help. You described some popping in the intake, therefore i would have fuel pressure verifed. Maybe change the fuel filter.
Chris
