Questions on what tach to get for my 95,also how to install,i like my digital cluster so i don't want to do the z28 add,just want to add 2-5" tach on the pillar,all info will be appreciated,Thanks
i did the same thing all u do if run the signal feed from the tach to the negitive terminal of the ignition coil. just try them untill it works you get it...
Doesn't sound hard at all,im actually starting over with a rebuilt engine,so while i got it all apart i can run a new wire to the cab
I just looked over the ss handbook and it has step by step to installin a tach,also i was wonderin what is the purpose of the tb bypass?
