1 - 1 of 1 Posts
LT1 to 383 rebuild - Trick Flow 195 Gen X Heads - CompCams LT1 XR276HR12 - 32lb injectors - 1.5 Rock
Does anyone have a picture of the connection ends between the Telescopic Antenna cable end to radio feed cable?
just replace the antenna and what I’m seeing looks like a RCA female to female connection point. Thinking one end should be male versus needing a connector. The body cable is difficult to access so I trying understand what it should look like to troubleshoot if my cable end might be damaged before digging in. I have searched and read the antenna based post but not seeing any pictures. Thank you for any help.
1 - 1 of 1 Posts
