1 - 11 of 11 Posts
Can I take the frontend from a 96 9C1 and put it under a 96 Impala, if so will I run into any major problems or issues that I need to prepare for before I get started? Or can I just unbolt the a-arms, steering, etc. from the 9C1 and bolt it back on to the Impala?
If you think I totally out of my mind.......YOUR RIGHT!
What are you trying to accomplish?
Only parts that are different are the lower A-arms and spindles (both set up for the 5/8" balljoints). Everything else is identical.
Usually, stripping used parts from a 9 year old cop car isn't gonna end up being much of an "upgrade" for the work ;)
Unless 9C1's FE was rebuilt[w/quality parts] recently, of course!
So do I forget it, or rebuild the 9c1 FE and place it under the Impala. Keep in mind the Impala frontend is a bit loose and could use a rebuild anyway.
my 2 cents are at least get the lower control arms and spindles that way you can upgrade your ball joints then do the rebuild
That's the best idea I've heard all week;
*Rebuild FE on one car[9C1],
*Then transfer all parts over to another[SS].
You are from this Planet, right? :confused:
You may be under the misconception, that FE bolts up to a vehicle in one piece? .......NOT!
FYI, it's rebuilt component by component.
Originally posted by LarryCigar:
</font><blockquote>quote:</font><hr />Originally posted by TBA96DGGM:
</font>[/QUOTE]So what about just swapping the lower control arms and spindles and then rebuild the SS FE? Will I gain anything or just wasting time?
Is there anything else worth swapping from the 9c1 to the SS?
The 96 9C1 got larger lower balljoints and spindles and lower a-arms to match. I know this will cause some heated debate but I say you will "gain" stronger parts where stronger parts are not needed. The original 9/16" joints got you this far keep the replacments well lubed and they will probably outlast the rest of the car, so I see no gain to the 5/8" joints.
A 9C1 and Impala are just another Caprice, get over it they are nothing special.
Discussion Starter · #9 ·
Originally posted by 96capriceMGR:
...A 9C1 and Impala are just another Caprice, get over it they are nothing special.
But I thought all 9c1's came with a special "cop chip"?
Kidding!
But what if he wants to be able to leap the tallest speedbump or jump the highest curb
96CapriceMGR is right, there isn't really anything special about having the 9c-1 frontend unless you plan on doin alot of the above. I have a 96 9c-1 and truthfully, I wish that I had just the standard. When you try to rebuild a 9c-1
most of the idiot suppliers out there don't know the difference between them and will send you the wrong parts, even though you clearly stated what you need
1 - 11 of 11 Posts
