Hi all,
I've owned this car since 2002, purchased used. It is not running, 383 spun a bearing about 7 years ago and transmission needs a rebuilt as well. I was going to pull the motor at one point but got too busy with work. So the front accessories and headers are off. Going back to school so car must go.
There is too much to list but will go down the line from memory:
-~180k miles, straight body, uninstalled ST smooth urethane bumpers, clean interior with minor wear and tear
-383 with aluminum heads, new opti-spark, 30-lb red top injectors, 52mm TB, aluminum racing radiator (needs leak repair), Meziere electric water pump
-Eaton differential unit with 3:73 gears, 3.5" aluminum driveshaft (Dennys I think), Clear Image tubular transmission cross members
-Hotchkis lowering springs, Bilstein shocks (stiff ones), Hotchkis front and rear swaybars, 1st design Rustic Racing front lower control arms (~3/4 turn only), Hotchkis upper/lower trailing arms
-18x10 (rear) by 18x8 or 9 Fikse FM5 forged aluminum rims on 295/35ZR and 245/45ZR Toyo Proxes T1R tires (less than 1k miles) = 1 rim has a slow leak, can't remember which
-HID Halo Headlights (by Mike I think), clear corners, '94 caprice rear taillights in DCM
Price: $3,000
Transport: Come pick it up
PM if interested and include email so I can send larger pictures.
Bump...new price $3k as is. Will be in Los Angeles mid December to sign it over if anyone is interested. Rims/tires alone are worth that much.
