Had a 95 column in temporarily from the junk yard due to a break in. All was good. Got the new column and floor shifter in now my OD doesn't work. Reacts as if it's in nuetral. You feel nothing catch as you shift into OD and if you press gas it just revs. D and all others work fine. Could cable be hooked up incorrectly? Installer claims he had to make a new bracket as mine wasn't fitting. Do you think this is the issue? I have relocated my vehicle to NY and can't take it back to the shop that did the work. Any help would be highly appreciated
What is the car that you're working on? My assumption based on what I read is this is a True 96 Impala with Floor Shift setup. Not sure with what you described as to why the "Installer" had to make a new Bracket but this could be your issue.
To me, it does sound like a linkage (Shifter, cable or bracket) problem not allowing the trans to shift correctly. I would first get to basics and get under the car, disconnect the Linkage at the trans lever and make sure that the trans shifts into all gears manually. Start with it in Neutral and then by hand turn the lever thru each selection.... Click (OD), Click (D), Click (2) and Click (1). If all looks good there, check and adjust the linkage from the shifter cable and have someone in the car go through each gear til you can determine why it wont engage into OD. Its probably just something simple that you need to be able to see while looking at it.
OK will be home in 2 weeks and try what you said thanks a million. Did some more research and found out a buddy that did some work here in alabama on my car had removed a bracket off my trans for some apparent reason that he felt wasnt allowing my trans to perform at maximum levels, now I'm ticked. Therefore the shop that put my floor shifter back in made a custom bracket because a piece was missing. I will find out the name of the exact piece. So at least I'm getting there somewhat.
