What is the best type of water pump to use that will fit for a 1996 impala ss with a 5.3 LS swap?
So far I found this:
Walbro High-Pressure Inline Fuel Pumps F30000271
Are you looking for a water pump or a fuel pump?
I think you need a minimum of 255 LPH, and maybe more depending on the HP you are planning to make. You can get a Walbro 255 (255 LPH) that will fit in the tank. 450 HP will require over 300 LPH. More than 255 LPH, and you are probably going to rework your in tank pickup, because the pump will be larger than the OEM mount. If you use an external pump, you will also be modifying the pickup in the tank, and you must mount the pump below the tank fuel level.
That helped a lot. It wuzz for a fuel pump and most definitely appreciate it
The first sign of a bad fuel pump will probably be a sound. It's normal for a fuel pump to make a low humming noise as it runs, and you might be able to hear it coming from the gas tank area. As a pump gets older and begins to wear out, the sound can turn into more of a loud whining or droning.
