so you re-soldered it and it lasted 2 weeks correct ?
so that says to me a poor solder job because it did work after you soldered it.
you do soldering often ? my guess not... so practice before you do it again .. and if you do change those resisters IMO you will destroy the odometer with the posted info you described on how this all played out.
the resistors in the odo are good since they did work 2 weeks ... solder NOT !
