I will start off by saying that I have spent the better part of my days from before Christmas searching and reading all the threads I possibly could on my issue here but am still at a standstill. With that being said, here I go...
I have a 96 Impala SS with 156k and about a year ago it just died on me while driving on the interstate. I figured the fuel pump was going out as it had intermittently did this before but it would always fire back up after sitting for about 10 mins. This time was different as it didn’t start up. I’ve had a couple buddies that are mechanics check it out and both said, “It’s your fuel pump. The engine isn’t getting any fuel.” So, I drop the tank, replace the fuel pump and sending unit as it looked to be original and figured I’d just replace with new (Autozone) unit. Replaced fuel filter as well. Thought it would fire right up and I’d be cruising again but no such luck. I read on another thread it could be FP relay so checked/replaced that, still no luck. Then checked PCM fuse next to FP fuse. BINGO... blown! Replaced that for it to immediately blow again. FP doesn’t even run and I’ve noticed my gauge cluster lights aren’t working. All other dash lights are, though. I’ve read that it could be the coil, ICM, grounded wire or a bad ground somewhere. I’ve checked the ground to the head at the ICM and on the trunk hinge and they are good. Without throwing more money at parts I don’t need to replace, what are your thoughts/ideas/recommendations? I’m prideful of working and fixing my own vehicles (plus, can’t afford to take it to a shop for repairs) so ANY guidance is greatly appreciated. Judging by the amount of threads on this issue, I hope someone has THE answer for me. Thanks in advance, patiently waiting...
