LT1 to 383 rebuild - Trick Flow 195 Gen X Heads - CompCams LT1 XR276HR12 - 32lb injectors - 1.5 Rock
Hey guys - looking for anyone that has Goodmark or KeyParts Cowl Hoods.
Key Parts @ $551 (plus $134 shipping - $685 total) - KeyParts 0829-035 Key Parts Steel Hoods | Summit Racing
Goodmark @ $886 (plus $134 shipping - $1,020 total) - Goodmark GMK4049200911
Interested in your thoughts related to quality, fitment, any mods required, fender hood alignment and ultimately if the Goodmark hood is worth the premium
. . . and if anyone has a recommendation on where to buy or selling one used.
Finally - if you could post any pics of you cars with cowl hoods it would be appreciated.
Thank you
  • Like
Reactions: nsaness
My review will be quite dated as I got the Goodmark when putting together my son's project car 20 years ago. An add-on scoop was simply not an option, and any fiberglass hood was a 'do not want' due to all the poor fit stories. I was not favoring a honking 3" style, so the GM came with good reviews and it had the added bonus of a tame true 2" ht.
Two angles:
Automotive parking light Tire Vehicle Wheel Car
Automotive parking light Tire Wheel Automotive side marker light Car
The fit using original hinges was/is perfect, and accepted an F-body cleaner kit just as well:
Car Motor vehicle Vehicle Hood Automotive design
I read some post on the Monte Forum a year ago that the holes are too small to permit adequate CFM if using a true cowl intake. The last time it was running it had a fuss opening the rear butterfly so either I just have the spring wound too tight or something to check on more seriously and no big woop to drill some/all out accordingly. Overall, 5x5 score.
Great pictures, the 5 out of 5 score on the Goodmark is helpful and thank you for the reply.
Update - so I did some digging, sent some messages and made some phone calls.
Confirmed that both these hoods come from the exact same supplier.
In this instance Goodmark buys this hood from KeyParts . . . in other instances KeyParts buys from Goodmark.
So buy the hood that you can get at the lowest price as they are exactly the same
If your a body shop or garage you should be able to purchase direct from Goodmark @ $681.53 plus $175 shipping - $856.53
  • Like
Reactions: nsaness
Hello guys. I have the key parts on my car. My buddy is a body man. Said best fitting hood he ever had in shop. Lined up great it's steel and price is reasonable
Thanks for the information SI. Glad to hear it lines up so well. Reassuring. I’m picking mine up next week.
